I have this stock BMW seat pan I want to set up on my 'low' mount hardware. What's a good way to remove the rivets that hold on the cover and foam?
Drill them out or what?
In the front I want to extend the pan to meet the modified side cover. Also, to give enough coverage over the battery and the ignition unit on the right side. The lower sides in the front won't be load bearing. I'm looking to buy a material that I will rivet and glue to the stock pan. What material and thickness could work?
This is the Corbin I have the extends to the tank and modified side covers. I don't want to mod the Corbin. I'll probably end up selling it, once a replacement is finished.
