darkmatter
Hey wrench turners
I have put 12K on this bike and now has 53K. I like it a lot but does seem to need this and that more than I would like.
All cleaned up and stripped of fairings etc and I see that the right side head gasket underneath is dripping under pressure and can see the gap. With U tube and these forums I think I can handle it.
I had a moto mechanic do a few things and charge me a bundle a couple months before it blew out on a camping trip. He pointed out that the paint on the upper side cooling fins right side was slightly bubbled. Overheated and I don't know when or why. Fairing plastic on inside near exhaust pipe curve also bubbled some.
Oil always up and regularly changed out etc. Don't ride it hard much. So the questions are: does this right side run hotter usually on these twin oilheads and what would cause one side to be hotter than the other? If I successfully replace the head gasket, etc. what is the chance that I have a warped mating surface or something that will result in another head gasket blowout down the road?
Thanks!
Steve
Thanks!
Steve
