greenmachine1100
Good morning!
Cycle has 90k miles on odo. Adjusted my valves a week ago. Took a day long ride about 4 days later. Found oil spray on the left side. Covered my boot, sprayed back to luggage.
Thought I under/over tightened valve cover (tricky. Think 2 on the right side are stripped. Think PO did it, because I was super careful)
Got around today to cleaning up the oil and thought I would be removing valve cover, put on some gasket dressing and tightening it back up.
Went to pull out plug wire, and a flow of oil cam out of the plug well. That is the source of the leak!
My question is: It is that donut at the center, base of the valve cover isn't it?
I re-installed them on the head first, as per the instructions. There's a chance I did it incorrectly, but I think I did it right.
Does that mean the gasket is probably ripped or just failed with age, or I installed it incorrectly?
Do you guys replace them at intervals?
I'm going to dealership right now to check price, and see if it is worth it to just replace and forget about it. Plus, be super, super careful about re-install.
