mcmlcccvrs
Well, I ain't a happy camper, kids. It certainly appears as though I have a coolant leak between the cylinder head and engine block. I had seen the green/blue dried remnants of coolant before and often wondered why I could detect a faint odor of coolant when the bike was hot yet there was no drip. Now I know why. I had the left and right lower fairing covers off today while doing something else and happened to be shining a flashlight in there while the engine was running. That's when I saw 2 or 3 tiny wet spots at the head to block joint. I suspect that whatever was oozing out was sitting along the joint and evaporating. I don't know if the gasket is leaking on the underside (I'd have to pull the belly pan) but it doesn't really matter I suppose.
Do these gaskets fail? All of my previous bikes were air cooled. This will be my 3rd season with the bike and I know I've never overheated it as I have a temp gauge. Can't speak for what may have gone on in the past.
The bad news? Clearly the work I need to do and wondering if anything may be warped. The good news? I'm up for it. Not intimidated by what would be required as many years ago I had two Suzuzki GS750 engines completely apart for rings and valve jobs. The valve jobs and cylinder honing was done at a shop but I did all the rest.
Any advice or anything else I need to consider doing while in there? AHHHHHHHHHHHHHHHHHHHHHHHHHHHH! And whatever expletives you deem appropriate!
