You want noise? Get yourself a '93 R1100RSL with an M93 transmission and you'll have noise especially at idle in neutral. But then one should never idle one's RSL else up in flames goes the plastic.
A casual look at cutaways of an LC motor alongside an earlier air/oil cooled motor will make obvious the source of the mechanical cacophony from the wethead. It has nothing to do with how your helmet fits and a little bit of water circuitry around the exhaust valves isn't going to muffle it.
check your valve clearances!!! my 2015 r1200rt developed a clatter this summer at around the 16000 mile mark . I had dealer check clearances ( at least they said they checked and I paid for them to check) got bike back said clearances all ok. Being an auto tech for the past 39 years I decided while bike is stored in basement this winter to check clearances myself ended up changing 7 of 8 shims all exhaust valve clearances where out of spec at .44-.45mm max clearance spec is .41mm finished and started bike yesterday. clatter is gone. Removing cams and cam holders was very simple. Bought a Haynes manual for this bike but they make it much harder then it is. procedure is very simple and easy. line up cams at TDC. mark cam drive and driven gears with paint marker remove cams reinstall by lining up paint marks no reason to remove chain tensioner or install crank locking tool. hardest part of this whole deal is making sure your micrometer is accurate. My 2 cents , but it works
BMW had a perfectly workable shim under bucket arrangement by 1983 on the two-valve K100 and K75 engines. .
Did you mean shim over bucket?
Whatever it's called I liked the K75 setup.
The problem is that you're not going fast enough.
At the correct velocity (and above, of course) the wind noise drowns out all else.
You're welcome.
Hard to hear the engine clattering over the screams of my passenger.
