Thanks for the help. I will try to find an adapter. We were trying to troubleshoot the fuel pump. I think he's going to get a replacement and see if that makes it run.
Sent from my XT1585 using Tapatalk
Adapter? It's possible I am wrong, but I don't think the typical GS911 can connect to the R1100RT. The company (Hexcode) makes a completely separate device that ONLY connects to the 3-pin interface found on the R1100RT and some other R1100 bikes ($99). Very limited function. It reads ABS-2 codes, Motronic codes and it can tell you if your TPS is within spec voltage setting. It also can clear the stored codes. You have to load the software on a computer and connect the device to the USB port on the computer.
