Anyone have issues with the BlueTooth system? I've gone to Bose noise canceling ear plugs and given up on BT.
Also, Somewhere there are pictures of spark plugs in which the lower plugs are black and the upper plugs are light brown (perfect in my understanding of what they should look like). Any progress of you trying to change the black to light brown by using plugs of different heat ranges?
Are the Bose ear plugs stereo earplugs supplying music? If so, the best way to take advantage of the stereo system on a later model RT is to use the rear speaker connector. You can purchase the adaptor from BMW that hooks into the rear speaker connector and wire in to 3.5mm female. You then locate the fador control and run up the rear speakers to max canceling out the front speakers and you're hard wired into the stereo system through the female 3.5mm stereo plug.
Scott
At 83k on my 2013 and I still have to top off about half a quart of oil every 6k or so. Haven't had to adjust my valves for the last 30k or so, so they really do seat in.
The Castrol RS 10W40 synthetic. It's annoying because it often needs a top off just before it's due for a 6k service. It also isn't always necessary.
Keep in mind most of my miles are done at about 4500rpm on the freeway commuting about 600 miles a week.
