Other than track day requirements of no glycol, what is the perceived need ?
I like the idea of eliminating the major cause of corrosion for the bikes system by getting rid of water in the coolant...
What if any is the corrosion concern with BMW water cooled engines? I have a few hundred thousand miles on water cooled K and F bikes with nary a corrosion issue so am curious why it seems to be a problem?
Paul,
wouldn't dirty mineral filled water Vs distilled water cause problems? I.e. water pump wear, possibly head a block wear if dirty enough.
Agree clean water and anti-freeze should not have any corrosion concerns.
