exgman
Active member
I took my RT to the Rally and along the way (in Cheektowaga, NY) filled up with Sunoco 93 octane fuel. I noticed that the engine started to seem to struggle some and ran slightly rough. It also had a sharp decline in indicated (on the BC) MPG. I stopped in at BMW of Grand Rapids and the SM there told me that it sounded to him as if I'd gotten some bad gas.
After consulting with Omega Man (thanks Gary!) I began adding Sea-Foam (1 ounce per gallon) at each fillup. That seemed to fix it, and pretty soon it was running mostly fine, but the symptoms return apparently at random. Sometimes it runs rough for 50 miles, then clears.
I continue to add Sea-Foam, and when I run out of that, I will switch to Star-Tron. I believe I got some non-ethanol gas in MI and MN, and that seemed to make it run better.
In terms of history, the bike has been maintained by BMW dealers exclusively and according to the schedule. Its most recent work was the recall on the fuel system, and the fuel pump was replaced at that time.
I'd sure like to hear if anyone else has had this kind of problem, and hope that someone has had a solution.
TIA - JG
TIA - JG
