Grips used to work fine, now don't. I checked voltage to the connector under the gas tank and it says I'm getting .03 volts on low and high settings. Fuse is good. I'm assuming previous owner installed it. PO also installed a European styled RH grip switch, on which the kill switch failed this summer. However when I bought the bike, he included the original RH grip switch, which I re-installed when the kill switch failed.
I'm wondering about the voltage (.03). What could be affecting the voltage? I'm wondering if the replacement switch is bad and that's why the PO replaced it with the EU switch. Any further checks I could make before spending a bundle on a new switch?
