m_stock10506
Well-known member
I have the LED setup for reading the fault code on my ABS-2 but I could use some help understanding what I'm seeing.
The LED is connected to the diagnostic plug and ignition is turned to ON. There is a brief pause of no activity, then there is a very quick flash of the LED at what I would call half intensity, followed by six very bright full intensity flashes. A second or two pause and then the sequence repeats itself (one half-power flash then six full-power flashes). So, what's that first half power flash? Does it get counted?
If I reset the fault code, I can ride away with no fault. Depending on ambient temperatures, the fault will occur again during a self-test after a stop. If it's warm out the fault will occur fairly quickly, 10 or 20 miles. If it's cool or cold out, the fault might not reappear at all.
