When I did my F800GS center stand-lowered 2" w/hyperpro- I used a pipe cutter to take the desired amount out. A pipe cutter leaves a ridge reducing the ID. I cut a bolt of approximately the same size and opened up the interior ridge so it was a nice friction fit. A slight relief 180 degrees apart for some weld to "wash" in from the mig welder-good to go. A little grind and paint, done. HTH GaryI have a r1200rt with hyperpro's lowered shocks. How do I go about lowering the center stand. Any welder or do I ask to have a tube but in before the stand is lowered?
That stand might fit your RT.. mebbe.
I'd want an inside tube or slug of steel to reinforce the weld..
Gary,Don's post led me to believe I wasn't clear...a quick sketch..
Hope this is more clear. Gary
On my F800gs it was no longer usable or you would need help to lift the bike. The side stand needed a shortening also or the bike was almost vertical when on the SS.Just leave it and use it as is... I do! How often do you use it anyway??
