Welcome, Guest! We hope you enjoy the excellent technical knowledge, event information and discussions that the BMW MOA forum provides. Some forum content will be hidden from you if you remain logged out. If you want to view all content, please click the 'Log in' button above and enter your BMW MOA username and password.
Beginning April 1st, and running through April 30th, there is a new 2024 BMW MOA Election discussion area within The Club section of the forum. Within this forum area is also a sticky post that provides the ground rules for participating in the Election forum area. Also, the candidates statements are provided. Please read before joining the conversation, because the rules are very specific to maintain civility.
I've never seen a tire with "bumps" like those before. I can't see how they're normal or serve any intended purpose. I'd take it back to the dealer and see if you can get a different brand of tire.
After 6,000 miles on my Anakee II there is no deformation on either tire. From my own experience I would say this is not a per se problem of the Anakee II.
Have the same issue on my '05 GS running Michelin or Metzler. Someone once told me it was a function of the telelever but I have my doubts. I have noticed it gets worse if your wheel has excess runout (wire wheels). Bad suspension can make the problem worse (happen faster). The only solution I've found is higher pressures. I run 40 to 42 in the front and the problem seems to go away.
Commonality 40 psi, next time when either of you installs a fresh tire use 32 psi and your problem will go away. It is not a tire problem but a case of too much air pressure. I had the same issues on my front tires until I lowered air pressures, as far as tire life typically I get 10k on a rear with close to twice for front.
