mindtrainer
Hello Everyone,
I could use some help. I just bought a K100 with an 2002 tag, so I'm assuming it hasn't run in at least 6 years. I replaced the filthy tank, fuel pump & filter, pulled and replaced the fuel rail and all the injectors.
I pulled the plugs and sprayed some oil in there.
She turns over fine. There is spark. The injectors are not firing (had them dangling with the fuel lines attached and nothing). I know the fuel pump is good and the injectors came from a running bike. I replaced the injector control unit & cleaned the plug for the engine wiring harness.
Please advise me where to go from here.....
Thanks.
Thanks.
