I learned something new to me today while prowling through the RepROM disc for some other info.
BMW publishes allowable out of balance limits for the front and rear of my 08RT. The front balance tolerance is 5 g and the rear balance tolerance is 25 g. Up to 80 g balance weight is allowed, an amount that would make me very uncomfortable because one clearly has one or more badly manufactured components at that point (most likely a tire creating most or all of the problem).
For those metrically challenged, for round numbers there are 30 g per oz.
This clearly shows that balance tolerance is much more important on the front- in fact a factor of 5X as important according to BMW numbers.
What I learned is that's a bigger difference than I expected. 2X or 3X wouldn't have surprised me. Fronts are more balance sensitive on everything else I own.
A 5g balance tolerance is also VERY SMALL, too small to readily detect in normal riding by most, and getting any tire to stay in that sort of limit over its life isn't likely without rebalancing at some point in my experience. I'll bet almost none of us rebalance tires during their life though that 5g tolerance suggests doing it somewhere before mid tire life on the front. I've never rebalanced a tire on any bike I've ever owned since I learned to ride in the 1960's, for example. The rear value of 25 g can be maintained throughout tire life fairly easily and does not suggest the need for periodic rebalancing of the rear.
Any thoughts from service guys or others seeing this thread? Is the BMW spec a bit of smoke for the real world or is a periodic front balance something we ought to be doing? Is it worth the time and trouble to pull, balance, refit? Why?
With apologies to the Bard, "To bead or not to bead?" IS NOT the question, despite tangential relevance.
