happy wanderer
Day Dreaming ...
I've replaced failed Hall effect sensors on my 96 R1100RT and need to check the timing. I made a couple of scratch marks before removing the old one as a guide but want to make sure the timing is right. I found two good posts; one by GSAddict and another with photos here: http://advwisdom.hogranch.com/Wisdom/Oilhead%20Timing%20The%20Easy%20Way.html
Both desribe a simple way to set the timing by cycling the fuel pump using the OT mark on the flywheel as a guide. Problem is my bike's fuel pump cycles once when I turn the key on, but moving the crank from 15 degrees back to the OT mark does not cycle the pump again as described in these threads.
The bike does fire up with the new hall plate installed at the marks I made but I just want to make sure the timing is right.
Questions:
- Can I use a timing light?
- If so, what timing mark do I set the plate to? The S mark (5 degrees advanced) or the OT mark?
- I also read that you can shove a 12 volt LED into pins 4 and 5 of the hall sensor connector and static time it to the OT mark that way. Is this the desired and most accurate way?
- What does BMW service do? Static or timing light?
I have always used a timing light to time engines if I had one and used a voltage test light to do points on old Chevys and such when no light was available. Timing lights are the most accurate I thought.
Thanks in advance for input.
Questions:
