mbellantone
AirandOil In NJ
Here's what happens:
Signals work fine 65-70% of the time but it never fails that at some point during the ride, (hopefully not at the inspection station, i dodged that bullet twice so far!), the signal indicator on the dash STAYS lit.
With the size of my fairing, (my wife calls it "the flying fruit stand") i can't tell if the signal is actually illuminated or not.
Anyway, my usual course of action is to turn off the signal, use my arms in the old fashioned way and hope that a twenty something cop doesn't pull me over. SOMETIMES it will work again, flawlessly in the course of the same ride. Sometimes it does not.
Here is the probable BIG clue for those in the know: If i end my ride with the stuck indicator on, (direction does not matter, left or right), then turn off the ignition, still with the indicator pushed one way or the other, THEN turn the ignition back on, the signals will ALWAYS return to normal function.
I cleaned all the contacts at the bulb end for all 4, cleaned the contacts in the handlebar for the thumb actuator and also cleaned what I thought was the contacts for the correct relay. Still no luck.
Any thoughts?
thanks in advance,
Michael
Any thoughts?
thanks in advance,
Michael
