A
awshucks
Anyone have a pic of the spanner type tool needed to remove exhaust nuts on the head on a '81 R100? Am going to attempt to fab one, need to know how many fins they contact. Tia!
You should be able to get a look at one on e-bay. I have 26 years experience in metal fabrication and welding, and would not attempt to make that tool. you can buy one cheaper. IMHO
Boy howdy, you got that right! I checked the link so kindly provided and am leaning toward the Ed Korn version. Any experience w/ it? My nuts are relatively new, under 5k for sure, so I may luck out there. Thanks again!
I recently lost over 1/2 quart of oil, left side smoking a lot on start up including front crossover pipe. Not the usual side stand puff's, bike's been on center stand. Compression test tomorrow eve, but can see a need for a nut tool real quick. All tips appreciated, including any errors in the Clymers, '81 R100. Will disconnect elect ignition and pull the carbs, although the latter is not mentioned in my Clymers. Would open throttle be as good? Opinions seem to vary on that.
