Beginning April 1st, and running through April 30th, there is a new 2024 BMW MOA Election discussion area within The Club section of the forum. Within this forum area is also a sticky post that provides the ground rules for participating in the Election forum area. Also, the candidates statements are provided. Please read before joining the conversation, because the rules are very specific to maintain civility.
I am in the same boat. and have found 3 viable options. one is the verholen device that moves the handles back 50mm. this looks good but we also need to purchace and install a extended brake line.
An other option is the ABM kit which replaces the top cap entirley and replaces the existing handles with a handle bar. It includes the brake line extender.
The third option is a device by transit dog which clamps to the fork ends and raises the exsiting cap with handles up and back. They state that a brake extention is not needed if the line is transfered beneath the key switch.
have you tried any of these options? There are so many variables; I am having trouble deciding. the limitations between fairing and the gas tank plus the existing narrow handle position make it difficult to decide.
I believe I used the verholen device that moves the handles back 50mm, and installed the longer brake line.
Not sure because I am in the middle of relocating my home, and the bike is currently at my son's house.
The only problem I had was, that after removing and reinstalling the brake line, I did not know how to do a proper brake bleed on an ABS system. Had to go to the dealer for that. (Would not be a problem now.)
You should also know that if I had to do this again, I probably wouldn't change anything, because I've become used to, and actually prefer the lower and forward riding position, as I have more control and better balance on the bike.
