Where can I get angled valve stems for my R1150R so that it is easier to check tire pressure and to pump up tires? Or is there a better way? Thanks.
I think A&S BMW has screw on 90 degree adapters which will do the same thing and you wont have to remove the wheels and tires. I have one and it works great!
Does adding that adaptor require re-balancing the wheels?
At the Redmond National Rally i asked the Metzler guy to mount up a set of angled valve stems for me. He did not want to do it, but would if i insisted ("customer is always right, even when they're wrong"). Said that they add angular weight and pressure to the rubber stem, possibly leading to a catastrophic failure. Said best to thread an angled adapter onto the valve stem for checking pressure, and then removing. I followed his recommendations.
You can/will do as you see fit (see, it amazes me as to how many riders will still do the "wrong" thing, as they know bette than the pros. whatever)
No you just install it to add air then remove.
OK...was the Metzler Man commenting on put-on-fill-remove [or leave on] 90 degree adapters or the ones Jim lists? I am putting on the ones Jim has when I install my TKC80s in a few weeks...
Wondered about balancing issue since these stems are off-center ...but mass is very low..and I will be balancing tire/wheels/stems as a unit anyway..
WAY too much hassle, just install the permanent ones.
Jim
Ah but the permanent ones require removing and reinstalling the tires. MAJOR hassle unless you are replacing the tires!
