P
pgods
Who out there has put out $1200 (not including the install)for a set of Wilber's on their GS? Is it worth it?
Thye are worth it to me. I am 5'8" I put Wilbers 2" lower on a GS and they are great. Joe
My question to you would be Why?
To lower your seat height? Or for comfort?
If its comfort I would'ent waste the money.
Racers have the best suspension but it has nothing to do with comfort.
its to hold the road, you cant steer with your tire off the ground.
I would spend the money on a good aftermarket seat!!!
I have ohlins and did not inprove my comfort at all, learned the hard way.
If the Ohlins didn't improve your comfort AND control - then they weren't working right.
I've ridden an 1150GS with and without Ohlins, there is a difference! Part of your answer has to be whether your riding will take maximum advantage of an upgrade shock package. If the bulk of your riding is on smooth roads or slab, it may a stretch to invest the money. There'll be an improvement but you will not come close to realizing the potential of the high end shock package. Ride a fair amount of fire road, washboard dirt, Pennsylvania or New York City type secondary pavement, you'll wonder why you did not make the upgrade sooner. (ask any New Yorker, this is no joke)
Motard
edit - Wilbers and Ohlins are pretty much apples to apples
The short answer is - yes - I do. Can't speak for anyone else - or you..So do you feel it is worth the 1500?
Because I expect a lot for that kind of money.
i've a set of wilbers,1"shorter,from klaus.he is great to work with.wilbers made a big difference.
