landev
Member
Greetings,
I have a 2015 R1200GS Adventure which I purchased new in July of that year. ~ 2 years ago I purchased a 2015 R1200RT which was near new (3100 miles.)
I performed the 12K service on the Adventure back in 2018 and found it kind of odd that clearances on all exhaust valves were out of spec the exact same amount @ .432mm (spec on exhaust calls for .34mm - .41mm (according to my service manual.))
If I understand wear, valves should get tighter as they wear, not looser... am I correct on that? If so, why did all 4 valves read looser than spec by .022mm? I recall thinking that odd when I did the service back in 2018.
What brings this to mind now is that I'm currently starting my 12K service on my 2015 R1200RT and have just measured the valve clearance on both sides. Again, all 4 exhaust valves are out of spec by precisely the same amount, i.e. .022mm loose @ .432mm. Intake valves are, as expected, a bit tight but still in the specification range.
I'm curious if anyone else has noticed this measurement while doing their service. 'Not a big deal to shim things down, but I find this very on on 8 out of 8 exhaust valves.
Again... just curious! Just a note, the bike was running beautifully when I shut it down for the season.
Thanks for any input.
Best,
-l-
Best,
-l-
