aapasquale
aapasquale
I have a 1994 R1100RS with 36,000 miles which is a beauty-about a month ago I removed the old silencer with catalytic converter because the inner pipe had corroded and fallen off inside and had gotten a little loud-I got a used one one from one of our members from the southwest for a song-turned out to be pristine-I removed the oxygen sensor from the old muffler and put it into the replacement-installed new muffler and alls good.....however, I'm noticing when I use the engine for braking, it backfires when it did not before-also, the mileage is down 6-8 miles per gallon-
does the Motronic unit need to be reset after this type of repair? Is it possible to reset by just pulling the fuse for it? Is it likely the old O2 sensor has a hand in this? Any thoughts would be much appreciated
Thanks,
Tony
Thanks,
Tony
