Front Fender
Does the front wheel have to be removed to remove the entire front fender ?
Hi there, you'll have a better chance on an answer if you can edit your post with the year and model information. After that I can change your title to make it easier for someone to see, for example, Front Fender removal '09GSA. Good luck. Gary
If you are referring to an RT then, yes --
