G
GTDOUG
Any help would be greatly appreciated in my search for a voltage leak on my 1983 R100RT.
When measuring this leak, battery voltage is 13.82 volts. With the ignition off, voltage measured is 12.82 between the negitive lead and negitive battery terminal. Voltage steadly drops until reaching 10.65 volts measured at this same location. I am wondering if this is an indication of where to start looking for this voltage leak?
A while back I took the R100RT into my local mechanic who had been maintaining this bike for quite some time. After a great deal of testing his only recommendation was to replace the wiring harness. This work was done, however volt leak still remained.
To me this might be an indication of a capasitor with the slow voltage drop. BTW all wiring connections in the charging system appear to be sound.
