Whether you ride a Rocky, a Rick, a Russel, or a Sargent, they're all going to work well. Just ask the folks who have them. But before you go shelling out the big bucks for a more comfortable butt, I would highly recommend spending far less on a set of Bead Rider beads and check out what a huge difference they make.
The beads stay between you and the seat so it makes little difference what the seat has going on. Chances are you'll find a big improvement with long days in the saddle plus you'll save a lot of money. If after spending the $35 on a Bead Rider and you're still not happy, then go to plan B and get a custom saddle. Don't start the other way around.
Unlike other remedies such as shearling pads or some foam device, the beads spread your weight over more area plus they allow air flow under you to keep you dry.
