cookie
Jeff
Am I the only one? This is getting frustrating, I lost two on the right side, then one on the left and now I lost another one. Went to True Value and found 8mm head for the 6mm x1.0 thread pitch with integrated washer. Then the 5mm x 80 t/pitch. Now I have 25/27 torx, 3mm allen, 8mm and 10mm hex to hold down the tupperware, a total of 5 non O.E. screws.
I need to go to the dealer and replace them, and I will. Has anyone used locktite on these fastners? I would try the medium strength but I was hoping I am not the first guinea pig to try it out.
Oh, by the way, the valves are b&*lls on accurate and the dealer did the t/body sync. I ordered a "twin max" just because I can. I will check the t/body, but you know the bike runs like a well oiled sewing machine, very little vibration!!:
Thank you for your ideas, I do appreciate it>
Jeff Anderson
Jeff Anderson
