PGlaves
#13338
So Paul, what do you recommend doing about the float situation. Obviously you are not in favor of the floats that do not absorb or deteriorate because of the problems you outlined............thanks......Dennis
I discussed this a couple of weeks ago (Supertech in Pennsylvania) when it came up in a Q&A Tom Cutter and I were doing. I think there are two possibilities:
1. Just replace the foam floats fairly often - every year or so. If they look brown, or you are getting dribbling, then replace them.
2. I am told - but have not seen - a new float which is a single hinged float assembly that looks in shape like the original foam floats - but which has hollow black plastic floats on the hinge. I am also told that these floats retain the use of the OEM vented float bowls with the overflow drain tube. Assuming these were described to me correctly they are what I would use.
