Support may have had you change the MTP settings, so that the GPS is seen as a drive (Mass Storage) rather than a media device (MTP mode). To reach "tech mode", power on, View Map, tap the speed indicator in the lower left, then press and hold on the speedometer for about 10 seconds until the diagnostics page appears. Select Configuration and Settings, then MTP settings.
Send it to the Palm Doctor. I'm the OP of the linked thread, and found the only solution was to have my Nav V's memory increased from 8GB to 16GB. The upgraded unit successfully mounts on both a newer laptop and older desktop, and works with both Basecamp and Garmin Express. I had the USB connector fixed as well.See if anything in this thread helps-
Size Matters with Garmin Nav V 2025.20
I've discovered the hard way that the latest map 2025.20 download for the Nav V is too large for the unit's internal memory. I've been going back and forth with Garmin tech support for a few days, with no success. Long story short: Garmin has a created a map for the Nav V that is too big for...forums.bmwmoa.org
Good luck.
Sent my 5 to the Palm Dr as the update files were too big for the installed card. He did the same with mine and never had another issue with downloading updates.Send it to the Palm Doctor. I'm the OP of the linked thread, and found the only solution was to have my Nav V's memory increased from 8GB to 16GB. The upgraded unit successfully mounts on both a newer laptop and older desktop, and works with both Basecamp and Garmin Express. I had the USB connector fixed as well.
I would look at getting a new SD card. My Nav V, I just updated to 2026.10 or .2, don't recallI recently tried to update my NAV 5 GPS. I got the message that it was connected to Garmin express but that a memory card was needed. I have a memory card in the GPS but it was not recognized. Any suggestions? Thanks in advance. By the way, the GPS is 11 years old.
