1991 R100GSPD Accessory Power Receptacle Question
leafman60
The BMW accessory power receptacle located lower left side of the bike below panels.
Mine is dead and I have not fully traced the wires to it. My wiring diagram does not even show the receptacle. I have a brown and a red/white striped wire out of the receptacle that goes up into a main wrapped harness that leads up to the front fairing. I haven't yet removed the fairing.
Can anyone here enlighten me on where the accessory receptacle's leads go? I would think something like that would be fused at some point but the small left side fuse block doesn't cover it.
Thanks in advance.
My Haynes shows a red/white wire from a "connection for additional instruments" leading to the fuse board, fuse F3 with connections 30U and 30A3 on either side of it. It seems that this circuit also provides power to the clock as well as the turn signal and cancelling unit. On other older BMWs, he fuses were in the headlight, but likely in a different place. In Haynes it says that the fuse holder is mounted at the front end of the tool kit tray.
On my 1993 GS that outlet is powered by the third fuse back in the fuse box behind the left side cover. It is hot all the time. Good luck
Hmmm, yes, I checked that 15A fuse early on but it was okay. I check the power to that particular fuse holder.
Here’s a pretty good wiring diagram, it shows a straight shot from the fuse to the outlet with no connectors in between.
I would go over the basics again, corrosion, how’s your ground etc.
I see that the Ignition Control Unit gets it's power from the same fuse so if your bike is running I would think the fuse is OK. Ground connections are just as important as power. How are you testing the power outlet?
The OEM power socket on the airhead GS has on the back side two connector pins that mate up with a connector wired back to the fuse panel. Those pins often corrode internally and lose connectivity, easily tested by pulling loose the connector and using a test meter to check connectivity from the pins to the center terminal and socket wall of the socket. Worth checking if your fuse is good and no broken wires detected. A replacement socket from BMW is very $$$ and the most common fix is to wire in a replacement from Powerlet or other vendors selling the DIN sockets.
Here is some blasphemy: Carefully disconnect the OEM wiring to that socket. Insulate the ends of the disconnected wiring. Connect the accessory socket directly to the battery using a fused 12v+ lead and good ground lead.
