jonas_abramson@yahoo.com
Hi Forum!
I'm in the middle of a clutch replacement on a 97 R1100RS.
After the gearbox has been installed it and we re-attach the cable it appears as if there's very little tension or not enough. The bike was sitting for two years, I don't know if that matters. I just want to make sure I did it right before we put the whole bike back together.
Maybe you can help?
Is the cable shot?
Did I reinstall the pushrod wrong?
Do I need to do something to the whole boot spring thing attached to the clutch arm?
Is there a base setting for the adjustment screw?
Thank You!!!
Maybe you can help?
Is the cable shot?
Thank You!!!
