Signal lamp question
billdor
I am installing a safe turn system (STS) on my 2006 R1150R which will self cancel my signal lights when I forget which is almost always. I have been trying to find a wiring schematic for this bike so that I can get the correct wire colors and ensure a correct installation and to help find a location to best access all of the wires.
The only schematic I have found so far is so small that I can not read the fine print for the colors and it does not seem to be for the right bike as it only shows one switch for both indicators instead of separate left and right switches as on my bike.
Any help would be appreciated.
Bill
Bill
Bill,
Have you considered a plug and play system like that offered by Kisan? No wiring necessary. Just replace your factory relay with the Kisan unit. Here’s the part for your bike. https://kisantech.com/signalminder.html?find=bmw-r-bikes-r1150r--r28--2006-511?amfinder
Bill,
Thanks TA but I have already purchased the STS system. I think you are right in that it would be a lot easier to install and I may yet go with ut if I can not make the STS work.
Bill
