roger 04 rt
For the past year or so I've been working on Wideband O2 installations on my R1150RT. This past weekend, a friend completed the installation of a dual Innovate Motorsports LC-1 on his 2011 R1200GSA. Here is a link to the main thread I've got going in the other forum: 2004 R1150RT Wideband O2 Sensor Project.
Over the past couple of weeks I've been working with the riders of a 2007 R1200GS and a 2011 R1200GSA to help them with their installations of dual Innovate Motorsports LC-1s. To my knowledge they are the first to install the LC-1 systems on the R1200. I'm taking this opportunity to preview the results.
There has been a lot we've learned about the installation and there is probably a small amount of fine tuning that will get done over the next month. The R1200 required different program settings but terryofperry has a GS-911 and was able to rapidly create the data that was needed to debug the installation. He's in Georgia and I'm in Massachusetts so the work was done by phone and e-mail. I'm surprised by how quickly this was accomplished.
The bottom line is that the 2011 R1200GSA has two Innovate Motorsports LC-1s installed and fully operational.
Just as a reminder, using the LC-1s results in a fully-functional Closed Loop integration with the BMS-K and requires no Dyno tuning to make it work, it leverages the full capability of the R1200, as designed.
Below is a chart of the two LC-1s, logging AFR data simultaneously, with histograms showing distributions of each independent cylinder's combustion, as measured by the LC-1, in the exhaust stream where the Wideband O2 sensors get installed in place of the stock Narrowband unit. From the results we have so far, the BMS-K is working, without the knowledge of the shift in Lambda (that's good), delivering richer fueling, and performance improvements similar to those of the R1150 installations.
