Today I drove 160 miles from Medina, Ohio to Detroit to "seal the deal" on the purchase of a 2004 R1150R. About to test drive and I couldn't get into 1st gear from neutral after repeated attempts. So I put it into 2nd gear, did not drive off, but then went to neutral and then it did engage 1st gear. So I test drove in a very large parking lot and went through the gears several times, did some rapid stops and swerves etc. However, several times it refused to go into 1st gear, and would only do so after first going up to 2nd. I know this isn't normal, or acceptable. When I got the bike back into the garage, the mechanic experienced the same thing. But when he rolled back just a couple of inches when in neutral, it easily engaged into 1st. I drove back the 160 miles pretty deflated as I was excited about the bike otherwise. Should I forget about it and find another bike, or is this probably just a minor fix? I don't have anywhere near enough tech knowledge to answer this question.
