TPMS on 2008 r1200rt front wheel- battery?
jimwjarmour
jimmy armour
HI , my front tire pressure monitoring system on my 2008 r1200rt ,doesnt show front tire pressure, is there a battery perhaps needs changing has a good tire on front so will not be removing it to look for faults , rear shows ok thanks in advance Mark:scratch
If original TPMS sensor then the battery is likely dead and the sensor needs replacing. No way to charge. Some have had luck in soldering a new battery in but either way need to remove the wheel and dismount the tire.
Added a bit to the title for clarity. The change also helps bring up the topic in the Similar Threads pane below.
Good luck.
