I don't know about Jemmons but I have a 2015 and my rear just went out and now the front is taking a long time to get a reading but still works. I'm going to wait till I need new tires firstWhat year and mileage do you have with your bike? I am thinking about buying new TPMS sensors from Woodys wheel works as I don’t relish the idea of having to replace them after I mount my new Dunlop TMM tires as they are a PITA to deal with…
Your reply to the OP popped up before my response.. but thanks for your reply as well. My bike is a 2018 GSA with 66k on it.. Maybe I’m still ok?I don't know about Jemmons but I have a 2015 and my rear just went out and now the front is taking a long time to get a reading but still works. I'm going to wait till I need new tires first
You will know when they start to go because they will start to take a long time to show psi in the tireYour reply to the OP popped up before my response.. but thanks for your reply as well. My bike is a 2018 GSA with 66k on it.. Maybe I’m still ok?
I’ve seen too many problematic items on Amazon to buy any safety-related items there. Other sources have been discussed in this thread.Has anyone had success with installing a TPMS sensor purchased from Amazon?
I was quoted $340 for the BMW replacement
Did the new one last?
Bike is 2015 GSA with original monitors. This is needed for rear tireWhat year and mileage do you have with your bike? I am thinking about buying new TPMS sensors from Woodys wheel works as I don’t relish the idea of having to replace them after I mount my new Dunlop TMM tires as they are a PITA to deal with…
Any idea if they last as long as the OEM ones? Or is it to soon to say.I've installed about 50 of the "off shore" versions of both the ones with the integral valve stem (spoked rim) and the "banana" style with the shear bolt holding them to the rim for the spoke mounted fill valve. (cast spokes)
They work very will and are less than $30 for a PAIR.
It takes me about 20min per wheel to install them and then about 10min at the bike with the GS-911 connected to get them paired to the RDC module of the bike.
The last 10 or so of these I've received come with the individual serial number on a sticker to be used for activation.
I keep a box of a dozen of them on hand to install at the Tech Days I hold and at the ART's events done with BMWST.com
Brad
Here's the link to the ones I've been getting lately, and the activation tool I need usually to register the TPMS to the RDC (receiver black box on the bike).
https://a.co/d/5LSkiNX
https://a.co/d/040IAex
Interesting. Which ones do you speak of? So you just install them and ride away and they will automatically start showing psi?The last TPMS BMW sender I bought from the dealer was ~$225? Is the new price $340? That's ridiculous.
The new sender is quite a bit smaller and takes a different bolt.
My experience now with new F/R senders on a 2015 RT is that they have both registered on the bike with no GS911 programming needed. Both were reading the air pressure on the dash within a couple of miles after install.
