wardjhwtaw
Does anyone use nitrogen to maintain consistent tire pressure?
For my purposes, a carefully selected gas mixture containing 78% nitrogen, 21% oxygen and a few trace gases works well and is readily available at a reasonable price.
Kurt,
The nitrogen thing IS about tire pressure. The post about temperature changes is one extreme example. The mention of aircraft tires is another.
But we're talking about extremes. The reason that nitrogen is used in aircraft tires is because 50 psi at sea level becomes much more at 35,000 feet. The temperature difference does not balance out the pressure. So in this case the stability of pure nitrogen is used.
The last car salesman I spoke to was telling me that the added accessory of nitrogen (at $1200) was an important safety consideration and I was a fool for not getting it if I were used to carrying children in the car! He further explained that the nitrogen molecules were larger in size and would not seep out of the rubber. I hope you all are impressed with this. He didn't mention that I had to go back to the dealer for nitrogen as the 7/11 didn't carry it.
So after careful consideration of this, knowing that I wouldn't be driving to Alaska or up to 30,000 feet and having experience with both car and motorcycle tires since the 60s; I figured that whatever advantage I would gain from pure nitrogen wasn't worth it. Not to mention the fear of contamination if I ever had to top off the air at one of those 7/11 money grabbing tire stations.
