gregfeeler
Dances With Sheep
Interesting. So, how would you think those differences in heat range for the Bosch and NGK plugs would affect performance, in our Flying Brick engines? Given your sense of the NGK plugs being 'a quarter step off' the Bosch plugs, which would give better performance, i.e, ability to deliver strong, repeatable spark, under heavy load or sustained high-RPM operation? From the way you said it, I took it to mean that the Bosch plugs were slightly better. But it might be hard to generalize about this... and maybe we're getting off into the weeds here!
To be clear, I never said I've seen differences between Bosch and NGK plugs for classic K-bikes - only that I've seen some differences between different "equivalent" plugs occasionally over many years of working on engines. I've never used NGK plugs in any of my K-bikes (I have/had seven) because I've always found the Bosch plugs at a good price. IF there is a difference, I wouldn't expect it to be of any significance for a classic K-bike.
