I've tried to reach tech support at Boxer2valve yesterday and they never called back. I would like to finish this job. I have a 1990 R100gs. I have a GS2 speedo bought from Boxer2valve. The instructions are not very complete. I have been able to mount the speedo and plug in the round 4 pin connector. I have installed the speedo cable and hooked it up. The speedo works though needs calibration for proper correct speed.
This leaves two connectors and a red wire. I believe the two connectors are for rpm and temperature but I don't see a sensor for temperature nor do I see instructions for attaching the sensor to the engine.
My main concern is the red wire. I am 90. % certain it should be always hot. Is this correct?
What is the proper temperature sensor and where can I get it? It does not show up on Boxer 2 valve. Where is it supposed to be connected to bike engine.
Any instructions for hookup of tach sensor would also be appreciated.
