jimvonbaden
Kool Aid Dispenser!
So, I got a couple sets of ROX Risers, a 1.5" up and back fixed set, and a 2" Anti-Vibe Adjustable set, and thought I would show the install process. Later I will review their effectiveness. (Note, most risers will install the same way.)
Very nicely machined, and comes with new caps as well.
First, bike on the centerstand, then pull 3 of four of the cap bolts, and remove one cap.
Lay down towels to protect your paint, and give you a soft place to put the handlebars.
Take note of the angle of the bars stock. You may want to use this as a guide to position them after the new risers are on.
Grab the bar end like this, then remove the last bot and the cap. Lay the bar down on the towels.
Install the new risers, and torque them down back to front at 19Nm. Then lift the bar into position and add a cap, lightly tightening the cap just enough to keep the bar from rotating. (Sorry I missed a shot of just the risers installed.)
Check your alignment, both in angle, and ensuring the bar is centered.
Install the other cap, and torque them down back to front at 19Nm.
Check alignment and that they are at the angle that works for you.
Note that there is no clearance issue with the screen.
Cables
In some cases, with risers of taller heights, the brake and clutch side cables need to be moved so they are not stretched too tight. In this case they were OK, but slightly tight.
Here you can see that the brake cable is a bit tight. We are going to move it outside the fork tubes to reduce the tension on the brake line.
First, cut the cable tie on the brake line and wires to the grip. Then add a new cable tie leaving them out, but the other wires in.
(continued)
Cables
(continued)
