gtgt_bangbang
Brembo Rebuild kit for the rear brake master cylinder does not include the inlet grommet ( grommet on top , where spigot for the hose in from reservoir attaches.)
Seems slacker of them; how to do a complete rebuild without the exposed rubber , loose & cracked seeping up there ?
No PN for this grommet in bmw bike fiches as far as I could find.
Bremo offer a replacement grommet + spigot as a Ducati part , apparently for reservoir relocations;
'78 uses the 0deg / straight spigot (PN 110312710) , but there are 45 & 90 angled spigots too , if you're into the kinky stuff.
A quick gander on duckduck finds the kit from $4 to $20 ,
Ought to get to that install soon, the new grommet sure looks & measures similar to the mushy mass that came off mine, but will update thread if there is some issue inserting it.
related ;
There is a 5/8" dia ball hone , close enough / suitable for both F & R on my model.
I broke-in a new hone in with a couple scrap-pipe passes before unleashing it on the soft aluminum cylinder at rear.
The iron master cyl, up front/undertank, was still pitted after honing , so got the Appleton Hydraulics "brass insert" treatment.
They took their time ( almost miraculously , the " adhesive drying this very moment) when I finally got through to them after ~3 weeks of no news.) but the repair looks fine
I saw a couple of Duc rear masters (available new) that look similar to the airhead part ( NLA new) , might be workable replacement
Most have different levers , but recall that one had the lever coming off same direction as airhead's , might be a swap
related ;
