thanks. what you supplied is info about the plug that goes to the tach. This model has the lights inside the tach as opposed to the ones on the pad. What I'm after is the three wires that were attached to my emergency flasher switch. confusing to me because there are so many unmarked pins. It's warming up today, so I'll get out to the shed with a meter and see if I can figure it out.I finally tracked down my BMW diagrams...a little hard to review on my computer screen. I found an 8-pole connector that says it's for the rev counter. For the pins shown, here are the colors that were connected:
1 - black [goes to headlight]
2 - gray/black [to speedometer lighting]
3 - brown/black [to starter relay]
4 - blue [to diode board]
5 - black (seems to go to the coil)
6 - green/blue [to plug on handlebar switch right]
7 - brown/green [to oil pressure switch]
8 - brown [appears to be ground]
Not my strong suit, but that's what I can make out.
OK. None of my diagrams show the emergency flasher on them.
Snowbum has a section on misc. electronics and in there he discusses the flasher:
https://bmwmotorcycletech.info/misclelectrical.htm
no confusion. as I suspected from the previous schematic, the wire colors did not match and the wiring to the switch has been basterdized. In an emergency, I'll just frantically wave arms.Jumping in late, I have the airhead hazard flashers on both of my bikes. I can say for certain, the three wires you have are not familiar to me. The system as in Snowbum's diagram has a dedicated plug for the back of the switch with more than three wires. wires were not just plugged individually into the back of the switch. There is a dedicated harness for the hazard lights. At least on the hazard system I am used to seeing.
The reason for the three wires is there is a internal LED in the switch itself that is dim when power is on and flashes bright when the flashers are on.
IF you don't have this switch with the internal LED, I am guessing your switch might be more in line with a K bike hazard switch. From what I recall, those switches do not have the internal LED.
As some K bike technology started to creep into the R bike lines the later part of the Airhead years, and with the GS and ST models being sort of oddballs from the other airhead models, It is possible a K hazard system was used on your bike.
LOL, sorry for any confusion. St.
I don't know if they worked. I bought the bike as a non runner with no battery . the turn signals did not work properly until I took apart the flasher and de oxid it. I will investigat the wiring though. good advice, thanks.How about…… I take it the emergency flashers worked before the tachometer cover was removed?
Try looking further back in the wiring to see where the wiring changes back to the original harness and mark the extensions. I doubt the previous owner(s) changed any wiring out of boredom.
It’s not black magic, its just time and investigation…….and some labeling tape so you don’t have to do this again.
