Like many of you I have probably read every thread on surging but I bought another 1999 R1100RS anyway. These bikes pull you in.
My question is - given the configuration I received the bike in what fueling was the motronic likely doing:
O2 sensor connected.
Dobeck R259 installed and pots set to baseline (LEDs were lighting)
Cat Code Plug Removed
No POT installed
Prev owner had done the original Lentini zero - zero
It ran good but the idle was around 1250 warm. I plan on a "new" 250mv zero = zero and probably a go with the techlusion or a try of the AF-XIED. I'm just curious about what the motronic was doing in the received config. Thanks.
No POT installed
