lbrackr756
Little Egypt Airheads
I have a 1980 R100RT with only 20k miles on it. Just bought it a month ago and have noticed a little problem when shifting. About 1 in 10 times when shifting from 1st to 2nd gear the bike ends up in a "false neutral" between 2nd and 3rd gears, i.e. it goes all the way through 2nd but doesn't get to 3rd. A second problem is, when downshifting from 5th to 4th the bike ends up in a "false neutral" between 4th and 5th. Downshifting again results in a real Karrunch! into 4th so it's best to upshift again to 5th then try again doing the downshift. This second problem happens with a little more frequency than the first one. The trans is otherwise fine, no noise and correct shifting in all other ranges. Now, I'm thinking, this bike has the (I believe) adjustable shift linkage. Could this problem be a result of this linkage being out of adjustment? Any thoughts out there would be helpful.
1976 R75/6
1980 R100RT
1976 R75/6
1980 R100RT
