gtgt_bangbang
QUESTION - What is height of stock un-laden Northern European HEAD LIGHT BRACKETTE ?
Im installing a TOP FORK CROSS BRACE and having a little fit up problem .
Everything was going so fine but theres a gap visible in pix between top brace and adjusting nut during last mock up .
( mock up; I still have to fake the top bearing's height contribution to the complete yoke stack , using some thin washers under cup here ,
old bearing is long gone so I cant just open its ID to make removing fork easier during fit up. New bearing way too tight to want to drive out for fun in case I have to move the fork legs again. Took some steps to assure those were parallel .. )
Problem is probably no more mysterious than the head light brackets are too tall, nimrod but I dont have the original measurements (ie before trimming BRACKET) and like to check before taking some more metal off. This thin stuff is hard to put back on if theres an actual problem struggling to get out elsewhere !
The fork tubes extend 160mm through the lower yoke (measures from the flat below where the signal stalk sits.)
The tubes are too short in the top brace and again a shorter Bracket would erase that too, but I was pretty sure I did modeled it pretty well and took off that amount accurately. Apparently not. dunno it was awhile ago,
thus a Help Request! - Can some one please measure accurately (calipers ) the height of a HEAD LIGHT BRACKET (#7 in parts pix)
without the grommets of course - just the as-original part in metal. This is a late 70s 100 , as if that makes jack squat.
If ya tell me that height , I promise a couple top shelf cheapskate tips that helped doing this job mo'better and muy easier than I've seen around.
