police crash bars on an 1100 rt
114975
Thanks in advance for all helpful opinions and advice. I recently purchased an 1100 rt. I would like to install some of the crash bars that the police models have had on their bikes. Questions are as follows: 1. Do they make crash bars for the 1100? 2. Will I need to drill or modify mounting points to my existing plastic? 3. Do you have a set of crash bars you are willing to part with? Thanks again. Cheers and God bless.
1. Yes.
2. Yes.
3. No. :D
This is more involved than you may initially perceive.
The bars are mounted on a series of brackets inside the fairing (this doesn't include the couple dozen fasteners, washers and spacers):
The fairings get a hole above the cylinders, and two other mounting points are inside the fairing -- one of which requires the centerstand to be removed to install the rear mount.
It's definitely doable, just expensive and tedious to do starting with a civilian bike.
EDIT: My suggestion -- from a cost and installation complication start point: look into the aftermarket cylinder head protectors.
Feel free to ask more Qs.
