So, Kent, as far as I know my '78 R100/7 came with dual FIAMM horns installed. Is that not factory? Sure looks like it...most other /7s I've seen have dual horns. Hard to believe that they're all installed after-the-fact without a relay.
Wouldn't the wiring loom be set up for the relay and could it have been installed? Where on the RS/S models was the relay?? Maybe the OP needs to check the physical location for the presence of a relay.
100/7 doesn't have a horn relay. Only the bikes originally equipped with dual horns have one, i.e. R100RS and R100S. That relay is under tank, the only relay in headlight bucket is headlight relay.
It didn't happen without pictures!! Did you happen to take any pictures so that someone in the future can compare to their bike?
