jhall
BMWMOA #24809
I plan to replace the factory heated grips with aftermarket ones. The main reason is so I can install bar end weights, which are needed to anchor the, "Knuckle Warmers" which are similar to Hippo Hands. Though the air is minimal blowing on the hands, the Knuckle Warmers make a significant difference. Also, I do not care for the ribbed surface of the OEM grips. Can install Grip Puppies on either, but probably not till spring, as they will likely reduce the heat transfer of the heated grips. I ordered Oxford Premium Touring grips, which come with a heat troller. But my experience is that they are cheap, and only last 1-2 seasons at most. So I plan to use the RT's original HI/LOW switch instead.
