Need a K75 Transmission. . .
Dan Kearney
Greetings All,
I took my 1987 K75 in to the dealer for a spline lube (First since I've owned it) and discovered that the splines on the input shaft are shot. Dealer says it'll cost a couple of grand to rebuild the transmission in order to replace the shaft.
So, I am in the market for a used transmission. My question is, what years and models can I scavenge from? Can I use K100 or K1100 transmissions?
I have one lead on a 1990 K75 transmission which the owner states has 175,000 miles on it but excellent splines. Any suggestions?
Thanks,
Dan K.
denver
IBMWR Marketplace
I am rebuilding a wrecked K75 and have had excellent results in locating used parts on the Internet BMW Riders Marketplace website. Most users of the Marketplace are reliable people, and I have yet to have a negative experience in probably two dozen transactions, from small pieces up to and including a full RT fairing. Of course YMMV, but I think this is a good parts source.
http://www.ibmwr.org/market/
You can scan the "for sale" ads or post a "parts wanted" ad. The ads are very well organized by type and also chronologically.
I am sure you can find what you need for much much less than the repair price you were quoted.
IMBWR Marketplace
Tom,
Thanks for the info. I have used the marketplace many times with results similar to yours. As a matter of fact the tranny that I talk about in my original post is from there.
Have you got any idea about cross-model, or cross-year compatibility?
Thanks,
Dan K.
How on earth can it cost "a couple grand" to replace an input shaft? Those things are like $300-400 brand new.
Check out this picture from the Clymer manual. It looks like the input shaft is easily replaceable. Can you find another dealer?
Compatibility K100- K75
I am not enough of a "K" expert to know for sure, but virtually all the parts I have replaced on my K75 rebuild project are compatible with the 1986 though 1990 K100 2-valve models. From time to time I have "borrowed" pieces from my project K75 and used them on my '88 K100LT. I even swapped the final drive temporarily from the 75 using it on the 100. A different ratio, but a direct bolt-up.
My educated guess is that the transmission from a 2-valve K100 will work on your K75. I don't know if they have the same gear ratios.
Any experts out there?
Trans rebuilt cost guesstimate
Jon,
I will be picking my K75 up at the dealer later today to get the full scoop from him. Off the top of my head I am willing to bet that the vast majority of that "couple of thousands of dollars" would be accountable to labor charges. It probably takes a number of hours to remove, disassemble, replace, reassemble and reinstall the trans. I've never done it, but that's my guess.
KBasa said:
Paging Mr. Eilenberger and Mr. Curry....
Dan has contacted me directly on this - to summarize my advice - as far as that dealer - RUN AWAY RUN AWAY..
The dealer is estimating $450 labor and about $500 in parts to replace a clutch disk and install the used transmission. That's about 3 hours labor for a non-ABS model (and that's me doin' it) and mebbe $100 in parts.
RUN AWAY RUN AWAY
:confused:
