Morning Reads: 4 September 2008
mika
Still Wondering
Happy Birthday
BMW PressClub puts out historical pieces periodically. While we were in West Bend last year BMW was celebrating ninety years. Here is PART III of three parts on the history of the company.
Ninety Years of BMW –
the Symbol of Innovation.
PART I. BMW Aircraft Engines.
PART II. BMW Motorcycles.
PART III. BMW Cars.
The spirit of innovation has transcended through the history of BMW for no
less than 90 years. And indeed, this ongoing innovation of the white-and-blue
brand has been borne out and initiated consistently by the creativity, skill,
and consistency of the company’s employees. The products created in this
process have at all times combined proven and new technologies in a
most characteristic manner, forming a sophisticated, trendsetting symbiosis
at all times.
PART III. BMW Cars.
Purchasing Fahrzeugfabrik Eisenach, the Eisenach Vehicle Manufacturing
Plant, in 1928, BMW established a third pillar for the company in addition to
the production of aircraft engines and motorcycles: the production of cars.
For reasons of time and to avoid any undue risks in the new market, the company
started out by continuing licence production of the Austin Seven which
began in Eisenach in 1927 under the model designation 3/15 PS DA 2.
Four years later BMW’s engineers had gained sufficient experience with their
new four-wheel products to introduce the first car into the market developed
by BMW itself, the BMW 3/20 PS. And indeed, this new model was full of
innovations right from the start, featuring a central box frame and independent
wheel suspension both front and rear, and thus offering a driving experience
customers had previously only been able to enjoy in far larger and more
luxurious cars.
Within just one year, the BMW 3/20 PS was available to customers not only
as a new car, but also with a new power unit, the new, 20-hp 782-cc engine
featuring overhead hanging valves and running much more quietly than its
predecessor. The seats, motoring comfort and lines of the new car were also
far more harmonious and modern than on its rather spartan predecessor.
The BMW 303: the first six-cylinder.
In 1933 BMW moved up to the highest realms of technology also in the
automobile market: Introducing the BMW 303, the company proudly unveiled
its second “home-made” car and the first BMW to feature the kidney radiator
grille. Within the engine compartment the new model boasted a 1.2-litre
six-cylinder in-line engine developing maximum output of 30 hp. The most
outstanding forte of the new car, however, was its excellent driving
and motoring qualities quite unprecedented in this part of the market.
BMW had opted for this power unit code-named the M78 after two former
designs appeared either too sophisticated or too primitive. The engine was
based on a four-cylinder introduced a year before and differed primarily
through the combination of the crankcase and cylinder block to form one
complete unit.
Further highlights were the camshaft fitted beneath the engine block and the
tappets operating the valves in vertical, hanging arrangement via rocker arms.
Both the intake and exhaust pipes were on the same side.
A feature quite unusual today was the varying gaps between cylinders:
The distance between the second and third, and the fourth and fifth, cylinder
were larger than the other gaps between the cylinders, with this extra
space being required to accommodate the crankshaft and camshaft bearings.
The crankshaft not using any counterweights therefore ran in four bearings,
just like the camshaft.
This was however not the main reason for this rather distinctive design.
Rather, the crucial factor was that back then the crankshaft was assembled
together with the connecting rods and pistons as one completely prefabricated
unit. And since the pistons thus had to be fitted into position from
below, the main bearing supports for the crankshaft were not allowed to
extend into the cylinder contours. Hence, the only option was to
accommodate the main bearings between cylinders further apart from one
another.
Highly inventive: using the exhaust gas to heat up the carburettors.
A similarly unusual feature from today’s perspective, but nevertheless quite
characteristic of BMW’s typical inventiveness, was to be found in the fuel
supply system, where the intake manifolds were enclosed by six-centimetrewide
chambers directly above the two updraught carburettors. Using the
heat from the exhaust system, these chambers served to warm up the fuel/air
mixture, eliminating the risk of icing and improving the distribution of the
air/fuel mixture.
In the years to come this engine served as the foundation for developing a
number of further six-cylinders, some of them even with an aluminium cylinder
head. Engine capacity was increased to two litres, and depending on power
requirements either one, two or three carburettors delivered the fuel/air mixture
to the combustion chambers.
Such a three-carburettor engine developing 40 hp was to be found in the
BMW 315/1, a light sports two-seater launched in 1934 and scoring a wide
range of success in numerous races and other contests. Indeed,
the sporting character of BMW cars began with this very engine and in this
particular model.
][bThe BMW 326: frame and body welded to form one unit.[/b]
Two years later, BMW launched a new top-range model immediately
acknowledged as one of the most advanced large-scale production cars of its
time: the BMW 326. This was in fact the first BMW featuring a bodyshell
welded to the frame, doors hinged at the front, a hydraulic brake system and
the spare wheel beneath a cover on top.
Proceeding from a newly developed low-bed box frame with a torsion barsuspended,
low noise rear axle, as well as transverse-leaf springs on the front
axle moved further down, BMW’s engineers had created an all-new midrange
model. The engine was also a new two-litre six-cylinder with two carburettors
and maximum output of 50 hp conveyed to the wheels by a partly
synchronised four-speed transmission even featuring a free-wheel function in
first and second gear. Top speed of the BMW 326 was an impressive
115 km/h or 71 mph.
The 326 was not to remain BMW’s only sensation in the year 1936. For the
next highlight appeared at N??rburgring on 14 June, when the brand-new
BMW 328 made its first appearance. This superior sports car was indeed the
result of a very fast development process, since the engineers, designers
and mechanics in BMW’s Development Division in Munich had had only little
time and money to make this thoroughbred sports car reality.
But while being forced to restrict themselves to the essential, BMW’s
specialists still had all their creativity to offer – and they were extremely
successful in bringing this creativity to bear: Within a short time, the new
BMW 328 dominated its category in motorsport, quite often leaving even far
more powerful competitors far behind. And this is understandable,
considering that 80 horsepower in the regular production version weighing just
830 kg or 1,830 lb overall gave this elegant roadster truly impressive power
and performance – and still does so today.
Elegant lightweight construction: the BMW 328 Mille Miglia.
BMW entered the 1940 Mille Miglia with unique roadster and coup?® models
built by Carrozzeria Touring in Milan. The thin aluminium skin on these
Superleggera bodies was mounted directly on the filigree, load-bearing tubular
spaceframe made of steel, reducing overall weight of the coup?® in road trim
to just 780 kg or 1,720 lb and allowing a top speed of 220 km/h or 136 mph.
The power unit featured in this legendary sports car was BMW’s first
automobile engine with V-shaped hanging valves operated not by overhead
camshafts, but rather by thrust rods and rocker arms. And since the
engine block featured thrust rod guides only on the intake side, a mechanism
in the cylinder head conveyed the operating forces via pivot bars and levers
to the opposite side of the engine.
A revolutionary test: the BMW 328 with fuel injection.
Featuring three downdraught carburettors fitted on the cylinder head,
the two-litre six-cylinder developed 80 hp in regular trim, accelerating the
lightweight BMW 328 to a top speed of more than 155 km/h or 96 mph
and soon becoming the very epitome of the sports engine.
But this was far from the end of the road for the six-cylinder, with engine output
being increased to 100 and even 110 hp on competition engines. The limit
in the process was set not so much by the engine as such, but rather by the
availability of fuel restricted to just 80 octane. This, in turn, limited the
compression ratio to a maximum of 9.5 : 1, in order to avoid the risk of the
pistons burning through. So it was only the introduction of special racing
fuel that enabled BMW’s engineers to overcome this limitation, increasing
output of the BMW 328 all the way to 136 hp. And in 1941 BMW’s
engineers even conducted tests with fuel injection on this outstanding engine,
using three throttle butterflies instead of the conventional carburettors.
The BMW 501: the “Baroque Angel” full of highlights in technology.
Losing the Eisenach Car Production Plant in the War, BMW found it difficult
to make a new start in the post-war years. Hence, the first new model did not
appear until the 1951 Frankfurt Motor Show – the BMW 501.
Although relatively “classic” in its design and styling, the “Baroque Angel”
was full of highlights in technology: The two half-shafts at the front were each
mounted on two triangular track control arms running in needle bearings.
This low-friction bearing technology ensured a particularly sensitive response
on the part of the progressive springs and suspension made up on each side
of a longitudinally arranged, extra-long torsion bar.
The arrangement of the dampers was likewise quite unusual: Fitted at the
outside on the lower triangular arms, the dampers extended upwards
in an inclined position, coming to rest inside on the upper track control arm.
This avoided any contact with the sprung body and prevented even the
slightest transmission of noise.
Focusing on the steering, the engineers in Munich introduced a very special
idea on the BMW 501, applying the principle of rack-and-pinion steering
to a crown wheel segment in the interest of maximum steering precision.
The oil reservoir for the steering served at the same time to lubricate all other
front axle components, which therefore remained independent of the
regular central lubrication. The rear axle, as all testers agreed at the time, was
the “ultimate level of perfection in the development of the live axle”,
torsion bars acting on the axle right at the outside via spring arms serving here,
too, to provide the necessary suspension effect and at the same time
giving the car its longitudinal guidance.
Even the gearbox with gears being shifted straight from the steering wheel
was arranged in a different position: Instead of being bolted directly to the
engine, the gearbox with its four all-synchromesh gears was housed beneath
the front seats and connected to the engine by a short propeller shaft.
The advantage of this particular arrangement was that the footwells remained
largely free, without being impaired or cluttered by a voluminous transmission
housing. A further benefit was that the engine mounts did not have to be
re-designed for maximum torque from the transmission, meaning that the
engine was able to rest on unusually soft and smooth mounts. The bottom
line, therefore, was that the 65-hp six-cylinder, a modified version of the
engine already featured in the BMW 326, was exceptionally smooth and
refined in the BMW 501.
1954: introduction of the world’s first light-alloy eight-cylinder.
The BMW 501 nevertheless only paved the way for BMW’s most spectacular
innovation in the ’50s: The first series-production light-alloy engine in the
world and the first German eight-cylinder after the end of the War launched in
1954. Weighing in at 210 kg/463 lb, the 2.6-litre power unit in the BMW 502
was just 28 kg or 62 lb heavier than the six-cylinder in the 501.
The pistons with four rings ran in “wet” cylinder liners, that is centrifugal-cast
liners surrounded by coolant pipes.
This solution was the obvious choice right from the start because BMW
planned from the beginning to build not just the 2.6-litre with its almost square
combustion chambers, but also a 3.2-litre with exactly the same stroke but
longer bore.
The oil pump on the smaller engine was driven by a divider shaft, the oil
pump on the larger engine by a roller chain. Otherwise the higher delivery
output of the pump might have overburdened the sensitive gearwheels.
The intelligent method used to fasten the rocker arm shafts in position once
again bore testimony to the inventiveness of BMW’s engineers, with the
inner support bolts on the bearing blocks, like the pushrods, being made of
special dura-steel and extending through the entire cylinder head all the
way to the housing at the back. As a result, the support bolts maintained the
same consistent distance to the crankcase also in the transition from cold
to high temperatures, even though the different metals warmed up at a varying
rate. The result was excellent valve play compensation between cold
and warm running conditions. BMW’s advertising experts understandably
highlighted this construction at the time as “automatic valve play
compensation”.
The valves themselves were positioned parallel to one another at a 12?? angle
to the axis of the cylinders. And so while this was not a crossflow cylinder head
of modern design where the valves hanging in V-arrangement are positioned
opposite one another, this configuration helped to save space, which was
rather limited within the engine compartment of the BMW 502.
To keep the warm-up period as short as possible, the eight-cylinder
featured an oil-guiding corrugated pipe within its water shell serving as a heat
exchanger: After the engine was started cold this configuration was able to
warm up the coolant more quickly to its regular operating temperature, while
when driving fast it helped to cool the oil.
Displacing 2.6 litres, the V8 with double downdraught carburettors developed
maximum output of 100 hp when it made its debut into the market.
continued
The new Range: technology at its best.
Even back in the mid-50s, BMWÔÇÖs development engineers recognised the
urgent need for a modern car in the midrange segment. And while
development activities to produce such a model were indeed initiated, the
project to build a brand-new midrange car was originally simply too expensive.
By the early ÔÇÖ60s, however, the situation had changed fundamentally and
BMWÔÇÖs new midrange model was eventually developed as a sporting,
medium-sized four-door saloon combining sports suspension with a powerful
engine ÔÇô sufficiently comfortable for five passengers, sufficiently agile
for dynamic motoring. BMWÔÇÖs marketing strategists therefore gave the car the
name ÔÇ£The new RangeÔÇØ, the BMW 1500 making its debut at the Frankfurt
Motor Show in 1961.
The power unit featured in the new Range was an all-new 1.5-litre straightfour
developed under the guidance of Alexander von Falkenhausen, at the time
BMWÔÇÖs engine wizard. Maximum output of 80 hp was sufficient for a top
speed of almost 150 km/h or 93 mph, quite outstanding compared with the
competition at the time.
Once again, therefore, BMWÔÇÖs engineers had made the very best out
of contemporary technology and the state back then, creating a concept
destined to achieve years of success. Proceeding from the 1.5-litre,
the companyÔÇÖs engineers soon introduced larger four- and six-cylinder power
units in turn serving to set new benchmarks and launch further innovations
in engine construction.
In 1966, for example, a patented cooling concept made its debut in the
two-litre version: The state of the art at the time was to use a thermostat on
the coolant circuit leaving the cylinder head, which opened up as soon as
the coolant reached a certain temperature, thus allowing cold water to flow into
the engine block. The disadvantage, however, was the excessive change in
temperature caused in this way, together with high loads acting on the engine.
BMWÔÇÖs new concept was to move the thermostats to the entry point into
the engine block, where, mixing cold water from the radiator and hot coolant
supplied by a direct line in the cylinder head, the thermostats helped
to maintain the temperature of the coolant flowing in at an appropriate, wellbalanced
level for the engine. This served, as desired, to increase
engine temperature in winter and reduce the temperature of the engine on hot
summer days. A further advantage was that it was no longer necessary
to switch between a summer and winter thermostat setting.
The first turbo made in Europe.
With its substantial power reserves, the four-cylinder opened the door for a
truly enormous increase in performance: Introduced in 1970, the 130-hp
BMW 2000 tii became the first BMW with mechanical fuel injection setting a
new benchmark in the two-litre class.
The debut of the BMW 2002 turbo three years later was even more
spectacular, this 170-hp top performer in the 02 Series reaching a maximum
speed of 210 km/h or 130 mph with its 170-hp power unit.
Built for a period of just 10 months, the 2002 turbo was available exclusively in
white and silver, the short production life of the fastest and most powerful
BMW 02 being a result of global decisions taken in the oil market: In response
to threats by the oil-exporting countries, the Western world imposed speed
limits and bans on driving, with the price of gasoline in Germany rocketing up
from DM 0.70 to DM 0.90 and clearly making life very difficult ÔÇô if not to say:
impossible ÔÇô for a car as technically sophisticated and progressive as the 2002
turbo. For the turbocharged BMW was once again an outstanding trendsetter,
being the first production car in Europe to feature exhaust gas turbocharger
technology.
Six-cylinder with innovative combustion chamber design.
As early as in 1968 BMWÔÇÖs engineers had derived a second engine family
from the four-cylinder destined to really characterise the image and reputation
of the brand: The straight-six power units featured in the BMW 2500 and
2800, once again taking the company back into the market of large saloons
and coup?®s. Fitted at an angle of 30o, these power units featured a crankshaft
running in 7 bearings and controlled by 12 counterweights for superior
smoothness free of vibration. A further feature was the overhead camshaft
likewise helping to give BMWÔÇÖs six-cylinders the ÔÇ£turbine-likeÔÇØ smoothness for
which they subsequently became so famous. Together with the forged
crankshaft running in 7 bearings and featuring two counterweights on each
crankweb, this was the guarantee for excellent running smoothness.
One of the technical innovations on the two engines boasting the same design
concept was the so-called ÔÇ£triple-hemispherical swirl-action combustion
chamberÔÇØ configuration literally cut into the pistons. This special geometry
served to generate exactly the right swirl effect, concentrating the fuel/air
mixture around the spark plug. The result was a very effective but at the same
time soft and smooth combustion process borne out inter alia through
the engineÔÇÖs superior power and performance: Maximum output of the 2.5-litre
was 150 hp, with the 2.8-litre developing an even more significant 170 hp ÔÇô
enough to catapult the BMW 2800 into the exclusive elite of 200 km/h
(125 mph) cars. And reaching a top speed of 190 km/h or 118 mph,
the BMW 2500 also far ahead of nearly all its competitors.
This new engine concept stood out from the start as a genuine role model
not only on account of its power and performance, but also because the new
engines were at the same time economical, robust, and long-living.
The BMW M1: paving the way for four-valve technology.
The BMW M1 clearly proved the great potential of the six-cylinder power unit
in 1978: this low-slung mid-engined sports car was powered by a 3.5-litre
straight-six delivering 277 hp to the rear axle. Code-named the M88, this truly
outstanding power unit was based on the M06 engine built in a large
production series and featured the four-valve cylinder head carried over from
the racing engines in the BMW CSL lightweight coup?®. Offering this kind
of technology, BMW took on a leading role in the introduction of four-valve
engine concepts
The BMW 524td: setting a milestone in the diesel market.
A genuine revolution in the history of BMW was the decision to enter the
fiercely contested market of diesel cars, developing a brand-new generation of
engines in the process. The first model produced in this initiative was the
BMW 524td launched in June 1983, BMW living up to the challenge to build a
diesel engine combining the advantages of diesel technology with the features
so typical of BMW such as dynamic performance and supreme motoring
culture. The result was the BMW turbodiesel based on the existing straight-six
power unit displacing between 2.0 and 2.7 litres.
Featuring turbocharger technology and large cross-sections on the intake
and outlet valves of the engine displacing 2.4 litres, the new diesel was able to
develop a substantial 115 hp maximum output. The turbulence chamber
combustion process enhanced to an even higher standard than before offered
ideal conditions for superior fuel economy and low combustion noise.
According to the DIN standard, this modern turbodiesel introduced by BMW
consumed just 7.1 litres/100 km equal to 39.8 mpg Imp, but nevertheless
offered top speed of 180 km/h or 112 mph and accelerated to 100 km/h in
13.5 seconds, setting a new benchmark for dynamism in a diesel.
A truly unique concept: the eta engine.
As an alternative concept, BMW also offered an innovative engine with
gasoline technology. This brand-new power unit was featured in the 525e
entering the market in 1983, the letter ÔÇ£eÔÇØ standing for ÔÇ£etaÔÇØ, the symbol
for efficiency. This 2.7-litre six-cylinder was optimised without compromises
for supreme torque and economy, developing 122 hp maximum output
but nevertheless consuming just 8.4 litres regular fuel on 100 kilometres ÔÇô
equal to 33.6 mpg Imp.
Back then fuel economy of this kind on a large six-cylinder was acknowledged
as truly sensational, all the more so as the engine hardly consumed any more
fuel under practical driving conditions than in standardised fuel consumption
tests. This focus on a large power unit with relatively low power was indeed
quite unusual in Europe, and remains so to this very day.
The BMW 750i: twelve-cylinder with the most advanced technology.
Three years later BMW came along with the sensation of the decade ÔÇô the
BMW 750i making its debut in 1987 as the first twelve-cylinder saloon built by
a German manufacturer since the end of the ÔÇÿ30s. This new BMW flagship
nevertheless remained relatively modest from outside, standing out from the
other models in the BMW 7 Series only through its somewhat wider radiator
grille and the wider powerdome on the engine compartment lid as well as
square instead of round tailpipes.
The BMW V12 was developed with the objective to provide a perfect
symbiosis of superior performance, compact dimensions, all-round economy,
and exemplary emission control. And the result was indeed truly unique also
in relation to competitors the world over.
These objectives were reached by using the most advanced, state-of-the-art
technologies and consistently implementing innovative ideas. Weighing just
240 kg or 529 lb overall, the five-litre V12 set up a new record also in terms of
weight and efficiency right from the start. And with its maximum output
of 300 hp, together with peak torque of 450 Nm or 332 lb-ft, the new V12
likewise outperformed comparable engine and vehicle concepts in the market
at the time.
The BMW Z1: a spearhead in technology actually available in the
market.
In 1988 BMW for the first time made the daring move to offer the market a
spearhead in technology built in series production: the BMW Z1.
This unique model was conceived and built by BMW Technik GmbH as a ÔÇô
very successful ÔÇô example of alternative body engineering, the company taking
a brand-new approach in designing and building this new car. As an example,
this revolutionary two-seater featured a monocoque-like, unitary frame
structure made of corrosion-free steel plate, while the bodyshell was made of
thermoplastic segments recyclable individually as required.
A particular highlight of the very modern body design was the side sections
retracting electrically into the car and taking the place of conventional doors.
Only the powertrain came from BMWÔÇÖs ÔÇ£regularÔÇØ production models,
the Z1 featuring the 170-hp six-cylinder carried over from the BMW 325i and
giving this roadster quite unique to this day a top speed in excess of 220 km/h
or 136 mph.
The BMW Z8: a unique combination of spaceframe technology and a
high-performance eight-cylinder.
Entering the year 2000, BMW again added further momentum to the
companyÔÇÖs leasdership in technology for the road, giving its revolutionary new
model the name ÔÇ£Z8ÔÇØ. And indeed, right from the start the BMW Z8
offered the best technology possible at the time in automotive engineering.
The trendsetting body structure of the Z8 was at least as exciting as the carÔÇÖs
design and style, the spaceframe aluminium body in unitary design
opening up a new dimension in technology. Built as a kind of truss structure,
the spaceframe incorporated high-strength structural aluminium plates
filling in the space between generously dimensioned extrusion-pressed
profiles serving as a stable ÔÇ£skeletonÔÇØ.
The beautiful aluminium outer skin then came on top of this structure,
with each component being fastened and removed with the help of bolts.
Keeping weight to a minimum in comparison with other open-air sports cars,
this concept ensured the highest possible standard of body stiffness.
The result for the driver was a truly excellent, direct feeling of the road at the
same time avoiding the vibration and body ÔÇ£trembleÔÇØ so typical of an open
car. And power was also abundant, a high-performance sports engine
displacing five litres and developing 400 hp offering everything the driver
required.
BMW X5 defining the new SAV segment in the market.
A year before the introduction of the Z8, BMW had already defined another
new segment in the market through the BMW X5, the worldÔÇÖs first Sports
Activity Vehicle (SAV).
From the very beginning, this all-wheel-drive newcomer supplemented the
sporting but comfortable features of a typical BMW saloon by offering a wide
range of offroad qualities. Measuring 1.72 metres or 67.7 inches in height,
the BMW X5 was a lot higher than all other BMWs. At the same time it was as
wide as a BMW 7 Series, but a lot shorter than a BMW 5 Series. And thanks
to its unitary body, the BMW X5 offered exceptional driving qualities both off
the beaten track and on the road.
This four-door Sports Activity Vehicle was built exclusively at the BMW
Spartanburg Plant in South Carolina, featuring both straight-six and V8 power
units.
In 2003 BMW added the more compact BMW X3 to its range of Sports
Activity Vehicles, for the first time offering a premium vehicle in the market
positioned beneath the BMW X5.
Optimum drive technology: BMW xDrive.
The highlight of the BMW X3 was the newly developed, intelligent xDrive allwheel-
drive system allowing infinitely variable distribution of drive forces
between the front and rear axles. Immediately recognising the need to change
the distribution of power, BMW xDrive responds extremely quickly to driving
requirements, generally faster when driving onroad than a wheel is able to lose
traction and, as a result, its grip on the surface.
This means that in a dynamic bend, for example, xDrive is able to feed exactly
the right drive power to the respective axle at all times, significantly minimising
both under- and oversteer in the process.
From VANOS to VALVETRONIC.
In 1992 BMW introduced infinitely variable valve management ÔÇô double-
VANOS ÔÇô as a world-first achievement in the BMW M3. The particular
advantage of this control system is that it adjusts valve timing on both the
intake and outlet valves infinitely to the engineÔÇÖs running conditions via precise
angle control of the camshafts, regardless of the position of the gas pedal
and engine speed. In practice this means substantial torque at low engine
speeds and superior power in the high speed range. And keeping the amount
of unburnt residual gases to a minimum, double-VANOS also serves to
improve the engineÔÇÖs idling qualities.
Special engine management control maps for the warming-up process serve
in addition to enhance the effect of the catalytic converter, with all of
these functions being masterminded by Digital Motor Electronics (DME).
The efficiency of BMWÔÇÖs power units was further enhanced to an even higher
standard by the introduction of VALVETRONIC in 2001. VALVETRONIC
is a valve drive system with fully variable lift management of the intake valves,
engine output being controlled by infinitely variable intake valve lift without
requiring the throttle butterfly previously inevitable on an internal combustion
gasoline engine. The intake valve lift function introduced in this way controls
the amount of air drawn into the engine, keeping power loss to an absolute
minimum (air volume control).
On the road VALVETRONIC technology gives the BMW driver enhanced
fuel economy, reduced exhaust emissions and, at the same time, even better
response and a higher standard of running smoothness.
The leader in light-alloy casting.
Shortly after the BMW brand was established many years ago, the company
opened its own light-alloy foundry because the aluminium components
provided by suppliers did not meet the quality standards applied to the IIIa
aircraft engine. And in the meantime, over the decades, BMW has acquired
unique know-how in the production of light-alloy components. Indeed,
this was the prerequisite for innovations such as the light-alloy flat-twin power
unit in the early ÔÇÖ20s, the worldÔÇÖs first aluminium V8 in the BMW 502 in
1954, and the complete changeover in the meantime of BMWÔÇÖs entire range
of engines to light-alloy technology.
The BMW six-cylinder: the only engine in the world made of
composite light alloys.
Introducing the first production engine with a composite magnesium/
aluminium crankcase, BMW hailed yet another pioneering achievement in
2004. Thanks to this unique casting technology developed by BMW inhouse
and now applied consistently in production, the straight-six weighs a
mere 165 kg or 364 lb.
This was followed in February 2006 by the Twin Turbo power unit featuring
High Precision Injection, again giving BMW a leading position in turbocharger
technology on large-scale production gasoline engines. Together with
BMWÔÇÖs straight-six diesel featuring Variable Twin Turbo technology, this power
unit ranks right at the top in the international market.
BMW EfficientDynamics: paving the way to sustained mobility.
Oriented to a process of long-term, innovative improvement, BMWÔÇÖs
EfficientDynamics drivetrain strategy combines superior performance with
minimum consumption of resources. In the year 2007 BMW introduced
an all-round concept of intelligent energy management with hybrid functions,
features such as Brake Energy Regeneration serving to enhance the level
of efficiency, in this case by generating electrical energy for the carÔÇÖs on-board
network solely while the engine is in overrun and during application of
the brakes. The Auto Start Stop function, in turn, also serves to use fuel with
maximum efficiency, optimising fuel economy on the manual-gearbox
version of the BMW 1 Series in conjunction with BMWÔÇÖs new four-cylinder
gasoline and diesel engines. To benefit from this new function, all the
driver has to do is shift to neutral when coming to a halt at the traffic lights or in
a traffic jam and let go of the clutch pedal. This automatically switches off the
engine, which is immediately activated as soon as the driver presses down the
clutch pedal again. Using this Auto Start Stop function, the driver is able to
reduce fuel consumption during standstill of the car to zero.
Over and above Brake Energy Regeneration and the Auto Start Stop function,
the new four-cylinder power units designed from the start for maximum
efficiency help to further optimise fuel economy in general. Precisely this is
why BMW offers the discerning customer two versions of new gasoline
engines with the latest technology of second-generation direct gasoline
injection. The big advantage in this case is that the new technology maintains
the lean burn mode with extremely efficient dosage of gasoline in the
fuel/air mixture throughout a particularly wide range of engine load and speed.
As a result, this new technology appropriately named High Precision Injection
allows a reduction in fuel consumption in everyday motoring by up to
14 per cent.
In series development, BMW is already in the process of electrifying the
drivetrain all the way to full hybrid technology. So based on an active
transmission combined with intelligent energy storage, a full hybrid will be
presented to the public within the next three years.
Since even vehicles with this technology will still emit CO2 while driving,
BMW EfficientDynamics focuses in the long term on the use of hydrogen
recovered in a regenerating process.
Indeed, BMW has already become the first carmaker in the world to launch a
luxury saloon with hydrogen drive built in series production ÔÇô BMW Hydrogen 7,
an absolutely unique car emitting virtually nothing but vapour when running in
the hydrogen mode. The particular feature typical of BMW is that
BMW Hydrogen 7, benefiting from its supreme 12-cylinder power unit, does
not require the driver or passengers to make the slightest concession in
terms of motoring comfort, performance and reliability. And since the car is
also able to run as an alternative on conventional premium fuel, it guarantees
unrestricted mobility also beyond the range of hydrogen filling stations.
Introducing this practical solution, BMW is clearly demonstrating not only its
leadership in technology in the area of future drive systems, but also in the
integration of hydrogen drive into a vehicle concept clearly proven in practice.
This, obviously, sets the foundation for an alternative to conventional
drive technology accepted in the market and readily available to the customer.
The launch of BMW Hydrogen 7 is therefore a milestone en route to a new
age of mobility independent of fossil fuel not only for BMW, but also for the
entire automotive and energy industry. And in this way, BMW is once again
clearly proving the unique innovative power and potential of an equally unique
brand.
This ends the historical series put out by BMW to celebrate 90 years of existence. Now back to our regularly scheduled programming.
Kinetic sculpture at the BMW Museum
<object width="425" height="271"><param name="FlashVars" value="requestUrl=http://www.bmw-web.tv/en/stage/playerxml?items%5B0%5D=Fpe3bOl"/><param name="movie" value="http://www.bmw-web.tv/en/player.swf?requestUrl=http://www.bmw-web.tv/en/stage/playerxml?items%5B0%5D=Fpe3bOl" /><embed src="http://www.bmw-web.tv/en/player.swf?requestUrl=http://www.bmw-web.tv/en/stage/playerxml?items%5B0%5D=Fpe3bOl" type="application/x-shockwave-flash" width="425" height="271" allowfullscreen="true" FlashVars="requestUrl=http://www.bmw-web.tv/en/stage/playerxml?items%5B0%5D=Fpe3bOl"></embed></object>
Current events at BWM NA
BMW GROUP (USA) REPORTS AUGUST SALES
09/03/2008
[ BMW Group US sales (BMW and MINI combined) up 1.0 percent in August.
Woodcliff Lake, NJ - September 3, 2008... The BMW Group in the U.S. (BMW and MINI combined) reported August sales of 30,931 vehicles, an increase of 1.0 percent over the 30,639 vehicles sold in August 2007. The BMW Group also reported a year-to-date sales volume of 217,821 vehicles, down 2.5 percent, compared to 223,341 vehicles in the same period of 2007.
BMW Brand Sales
Sales of BMW brand vehicles decreased 4.1 percent in August for a total of 25,462 compared to 26,562 reported in the same month a year ago. Year-to-date BMW brand sales were down 7.4 percent, to 180,889 vehicles compared to 195,436 vehicles sold in the same period in 2007.
"In the last six months in a tough economy we have seen premium brand sales largely supported by the Northeast region," said Jim O'Donnell, President of BMW of North America, LLC. "In August however the Southeast and West came back as a strong contributor to our BMW sales. A trend? Don't know, but a good sign."
Contributing to BMW sales in August was a good balance between retail financing and leasing.
"We are strong believers that the premium market deserves a choice of both retail financing and leasing," said Jim O'Donnell. "We knew working our APR programs to add a bit more value to the ownership equation would get us a better balance with leasing. This month it's been exactly like this."
BMW Automobile Sales
BMW's automobile sales are down 5.6 percent in August to 19,653 versus 20,825 in the same month a year ago. Year-to-date sales also decreased 7.1 percent, to 142,436 automobiles compared to 153,303 in the same period of 2007.
BMW Sports Activity Vehicle Sales
Sales of BMW Sports Activity Vehicles increased by 1.3 percent in August to 5,809 vehicles over the 5,737 sold last August. Year-to-date, sales of BMW Sports Activity Vehicles were down 8.7 percent, to 38,453 vehicles compared to the 42,133 sold in the first eight months of 2007.
MINI Brand Sales
MINI USA reported August sales of 5,469 automobiles, up 34.1 percent from the 4,077 cars sold in August 2007. Year-to-date, the division reported sales of 36,932 automobiles, an increase of 32.3 percent, compared to the 27,905 cars reported in the first eight months of 2007.
"MINI continued to see strong demand in August and one that again lowered our inventory even more," said Jim McDowell, Vice-President MINI USA. "But good news is on the way as we have increased our allocation for the remainder of the year starting in September."
McDowell noted that 75 percent of all MINI customers will likely build their vehicles to order. "This trend shows that MINI customers continue to be those choosing more for lifestyle and individualization rather than just downsizing for fuel economy."
Table: Sales BMW of North America, LLC, August 2008
August
2008
August
2007
YTD
2008
YTD 2007
BMW brand
25,462
26,562
-4.1
180,889
195,436
-7.4
BMW passenger cars
19,653
20,825
-5.6
142,436
153,303
-7.1
BMW light trucks
(SAVs)
5,809
5,737
1.3
38,453
42,133
-8.7
MINI brand
5,469
4,077
34.1
36,932
27,905
32.3
TOTAL Group
30,931
30,639
1.0
217,821
223,341
-2.5
BMW Certified Pre-Owned
Sales of BMW's Certified Pre-Owned vehicles are up 26.7 percent, to 9,453 CPO vehicles versus 7,462 vehicles reported last August. Year-to-date, CPO sales are up 21.8 percent, to 69,437 over the 57,024 reported in the same period in 2007.
BMW Group Canada sales up 12% to achieve best-ever August sales.
09/03/2008
Whitby, Ontario. BMW Group Canada reported today a new August sales record of 2,407 BMWs and MINIs, an increase of 11.9% compared to August 2007. Year-to-date sales for BMW Group Canada are 19,233 units, an increase of 2.6% over the same period last year.
BMW Brand: BMW sales hit a new August record.
The BMW brand set an August sales record of 1,902 units, an increase of 2.5% over August 2007. Year-to-date, 15,876 BMWÔÇÖs have been retailed, an increase of 2.6% compared to the same period last year.
BMW Motorrad Canada sales increased 37.8% to a new August sales record of 175 units. Year-to-date, BMW Motorrad has achieved a new sales record of 1,317 units, an increase of 3.1% compared to the same period in 2007.
BMW pre-owned set an all time best monthly sales record. For the first time, BMW pre-owned sales crossed the 1,000 unit mark when 1,002 units were sold in August, an increase of 35.0% over August 2007. Of those August pre-owned sales, 841 units were BMW Certified Pre-Owned sales, an increase of 66.9% over August last year.
Year-to-date, Certified Pre-Owned sales are up 16.3%, with 5,073 units sold so far. Total BMW Pre-Owned sales have increased 4.2% year-to-date to 6,134 units.
MINI Brand: MINI sales up 71%.
MINI achieved its best ever August and the fifth consecutive month of best-ever monthly results. MINIÔÇÖs August sales were up 71.2%, compared to August 2007, which translates to 505 MINIs sold. Year-to-date, MINI sales are 33.4% ahead of the same period last year, achieving a new year-to-date record of 3,357 units.
MINI NEXT certified pre-owned vehicle sales were up 129.2% to 55 units in August compared to August 2007. Total MINI pre-owned sales for August increased 113.3% to 96 units, compared to August 2007. Year-to-date MINI NEXT sales have increased 56.5% to 396 units. Total MINI pre-owned vehicle year-to-date sales are 661 units, a increase of 60.0% compared to the same period last year.
While in the UK they are resorting to giving things away to move RTs
BMW Motorrad offers complimentary navigation system with the R 1200 RT tourer
09/03/2008
Hot on the heels of the recent launch of its brand new satellite navigation system - the BMW Motorrad Zūmo - BMW Motorrad is pleased to announce that all customers purchasing an R 1200 RT, between 1 September and 19 December 2008 (inclusive), will automatically qualify for a complimentary BMW Zūmo and mounting kit.
The BMW Zūmo was launched in July this year with a variety of rider-friendly features giving it an edge over other car-based navigator systems and providing an economical alternative to the popular Navigator III.
The Zūmo is highly advanced but easy to use. The bright display makes it easy to view in any conditions, while the large icons and left handed controls make it more functional and easy to use. In addition to being waterproof, the system comes with a fuel and UV-resistant screen.
The ZūmoÔÇÖs Bluetooth capabilities provide hands-free communication, enabling it to be linked to the riderÔÇÖs helmet and a mobile phone. The navigation system also comes pre-loaded with full European mapping, all ready to plot and go. Routes can even be loaded onto Google Earth, enabling riders to display and share routes with others.
Further features include MP3 compatibility, a JPEG picture viewer and an extensive ÔÇÿPoints of InterestÔÇÖ database that provides highly accurate and useful information.
The BMW R 1200 RT remains unchallenged as the king of all tourers, recently topping RiDE magazineÔÇÖs RIDER POWER survey as BritainÔÇÖs best bike. This popular ÔÇÿBoxer twinÔÇÖ is available with optional Electronic Suspension Adjustment (ESA), while the complimentary Zūmo (normally priced at over ?ú500 with the mounting kit) adds real value for customers.
For further information on this offer, or to find your local BMW Motorrad dealer, please call 0800 777 155, or visit www.bmw-motorrad.co.uk
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/dZvhdr2ZCAQ&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><embed src="http://www.youtube.com/v/dZvhdr2ZCAQ&hl=en&fs=1" type="application/x-shockwave-flash" allowfullscreen="true" width="425" height="344"></embed></object>
motorcycledaily.com: High MPG models still primarily for Europe not the US
topspeed.com: 2009 Victory Vision
visordown.com: Classic Vincent smashes British auction record
Video: HusabergÔÇÖs radical new motorcycle explained
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/lUyt_e7cHtY&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><embed src="http://www.youtube.com/v/lUyt_e7cHtY&hl=en&fs=1" type="application/x-shockwave-flash" allowfullscreen="true" width="425" height="344"></embed></object>
ISDE2008.gr: All the daily news from the source
ISDE Day 2 Video
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/mRqy8I8m-pk&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><embed src="http://www.youtube.com/v/mRqy8I8m-pk&hl=en&fs=1" type="application/x-shockwave-flash" allowfullscreen="true" width="425" height="344"></embed></object>
topspeed.com: TeslaÔÇÖs future sedan rendering
autonews.com: Rolls-Royce ÔÇô China tax hike will not dent growth
motorauthority.com: Veyron driver attempts impromptu tractor impression
canadiandriver.com: Auto Tech ÔÇô Does your car push?
Stuff
MichelinÔÇÖs Tweel makes an appearance again. thefutureofthings.com: The airless tire
howstuffworks.com: How brainwashing works
forums.bmwmoa.org: experiment ÔÇô you folks write the sig line policy
Packers Blog ÔÇô jsonline.com
Packers.com ÔÇô News from the football shrine
Green Bay Post Gazette: Packer News, Commentary
Offical site of the Premier League
GasBuddy.com has gas temperature maps intended to let you see what gas prices are around the US and Canada. Areas are color coded according to the reported local average price for regular unleaded gasoline.
US
Canada
Bike Candy
From the Kneeslider.com
THE END
